impatient....
So I have the OME HD lift now with 33's ..... how bad would i b screwed if i put my 35's on without control arms.... i plan on getting them put on soon:yup: hopefully when i do the gears and stuff
Free reign on opinions...... |
Originally Posted by chickenman
(Post 1362612)
Free reign on opinions...... I had 35's on mine with no changes and I was fine... but if I started to wheel her I would hit my rubi rails.... If I put 5 people in the truck I would hit the rails... I ended up cutting them 3 inches... Now if you put in those rear lower ? I think ? in then you might not have to cut the rails at all.... but I had to cut mine because I dont have control arms... YET! :) WOOHOO |
Hey man congrats on the win:clap::clap:
I trimmed the pinch seam and rails yesterday getting ready for this weekend:yup: I have gears, diff covers , other odds-n-ends next week plus i am getting a BL for some extra lift:ya: thanks for the insight |
<--has yet to use anything besides stock arms
JKKAT, you may have only used stock arms but the OP has twice the lift you are running, so he is in a whole different situation.
The need to adjust castor is based on lift height, not tire height. You may want to toe in a bit, and you may have more issues with rubbing, but the flightyness/bumpsteer/etc should remain unchanged.
(Post 1362627)
ordered the 5.13's from david, figured since i will be swapping the 33's and 35's in and out :what?::crazyeyes: they would be good... will know more next week after i get them installed:clap:
Originally Posted by joey2times
(Post 1362617)
If I put 5 people in the truck I would hit the rails... I ended up cutting them 3 inches... Now if you put in those rear lower ? I think ? in then you might not have to cut the rails at all.... but I had to cut mine because I dont have control arms... YET! :) WOOHOO Looking forward to seeing you guys @ RC this weekend. :ya: My experience: since the BFGs are a little smaller they have so far cleared my Unlimited's rubi rails and pinch seam. looks close but clears. DtownJK is running a similar setup and I'm pretty sure his clear the rails/pinchseam. I think Joe's shoes are bigger so he had to chop. You'll want to slap on some extended bumpstops F&R if you don't have them already. As noted earlier it will be totally driveable with the 35s... the flightiness just feels slightly more pronounced to me. I have TF front lowers on order so we'll see if that helps. |
I think i read that WOL put front upper adjustable control arms on cindy's JK, you might want to send him a PM, im sure he can give you real life advice:yup:
