Improving Ride Quality
Old Dec 30, 2015 | 08:27 AM
  #21
SOAZ JK's Avatar
Originally Posted by Kojack
Thing is you don't need d60s and long arms to have an awesome off roader. putting anything over 2" of lift without anything to correct geometry is not advised. You have 5" of lift according to what you have on your rig. why all the lift? 35" on a 2.5" lift is a great setup. I would remove what you installed. sell it, get a good quality 2.5" lift, and enjoy a jeep that can go very far off road and still maintain on road ride quality.
I wheeled with the TF BB spacers, shock extenders, cheap disconnects and bigger tires on stock rims for two years. Never had any problems! I'm a firm believer that these JK's don't need more than 2.5" of lift, maybe a 1" body lift on top of that. Hope you get it figured out OP!
Old Dec 30, 2015 | 12:36 PM
  #22
Kojack's Avatar
I am pretty well on that setup now. with better shocks.
Old Dec 30, 2015 | 12:59 PM
  #23
vgullotta's Avatar
I'd bet dollars to donuts your issue is your rear driveshaft. That much lift tears them up. I have 3" of lift that has sagged to probably 2.75" and I still go through them every few years. Until you can properly rotate the axle and correct that, you'll keep killing the stock driveshafts. With your extra lift in front, you run a good risk of killing the front one when you're using it offroad as well. Mine is a 2 door though, and if your's is a 4 door, you do get a little bit more leeway in the amount of lift, but check it out.
