Input on lifts ?
Old Jan 25, 2013 | 01:38 PM
Temple333's Avatar
Default Input on lifts ?
I was thinking about getting a rough country 6 for my 2013 jeep rubicon but people say ill have to change my axels... I don't really want to get into that kinda stuff right now. So is there any truth to this?
Old Jan 25, 2013 | 01:52 PM
Atch's Avatar
Change your axles because of a lift? Thats funny, what reasoning did they say for that?? No you don't need to change your axles because of a lift. You would change axles because of tire size
Old Jan 25, 2013 | 01:57 PM
Temple333's Avatar
It actually says on the rc site under notes that 2012-13 modules require exhaust modification to clear the front drive shaft then goes on to say front and rear drive shafts are required to replace the factory limited travel shafts
Old Jan 25, 2013 | 02:02 PM
Atch's Avatar
And? That's your drive shaft not your axle. You can either get an exhaust spacer or a new front driveshaft. No matter what lift you go with you'll need to address this. If you have a 2dr you'll need to get a new rear driveshaft also due to the steep angle.
Old Jan 25, 2013 | 02:08 PM
BlackRockBurner's Avatar
If your going big, be ready for big expense. 6" lift, are you planning on 40" tires? If you want 35" tires, you can go with a 2.5" lift. Any lift over 3" will affect your driveshafts. Larger than 35s on tires mean a greater possibility of re-gearing.
Teraflex has two great YouTube vids regarding tire size and lift. It will answer many questions. They are also a great sponsor.
Old Jan 25, 2013 | 02:11 PM
Temple333's Avatar
Shitty I guess it's cheaper for me to go with a 4" then and get a body lift
Atch's Avatar
What size of tires are you looking to run?
Old Jan 25, 2013 | 02:19 PM
Temple333's Avatar
35 for sure maybe 37 depending on the price
Old Jan 25, 2013 | 02:21 PM
Atch's Avatar
You can run 37's with 3.5" of lift and flat fenders so 4" would be more than enough for ya without the body lift
Old Jan 25, 2013 | 02:26 PM
Temple333's Avatar
Oh sweet well I guess I'll save myself some money on the lift and get the 4" and go with the 37
