install 3/13
Old Mar 7, 2012 | 02:04 PM
ninjajmoney's Avatar
Default install 3/13
So I am going to install my FT control arms on 3/13. I was wondering what length I should make them for a 2.5" lift ? I am replacing all 8. Thanks in advance.
Old Mar 7, 2012 | 02:21 PM
ditchdigger's Avatar
If you buy a kit it should tell you how long to make your arms.
Old Mar 7, 2012 | 02:27 PM
I bought them used from a forum member.
Old Mar 7, 2012 | 04:54 PM
Bump for some answers.
Old Mar 7, 2012 | 05:15 PM
superjk10's Avatar
Go to projectjk.com , Whrite up check out full traction 3" he tells u the mesurent of all 8 arms
Good luck
Old Mar 7, 2012 | 05:39 PM
Good luck
I have looked at the write-up but I was not sure if it would work for a 2.5" lift.
Old Mar 7, 2012 | 05:42 PM
mkjeep's Avatar
Set the frt lowers 23" eye to eye. It's a good starting point. Especially if your just installing front lowers. Since you have stock bumpers you most likely have 3 in or so of lift in the front w the TF coils. Edit, oops see u got all eight, yeah, set them per the 3in lift write-up
Old Mar 7, 2012 | 07:08 PM
Will do . thanks again for the input guys. I love this forum
