Install Time
Old Sep 22, 2009 | 04:16 AM
cunningwolf09jk's Avatar
Default Install Time
OK so Im tring to get a idea how long it will take me to install a teraflex 2.5" coil lift and a adj front track bar.
This will be the first lift my friend and i have ever done but he is a mechanic and ill beable to use air tools and a lift. So how long will it take? no breaks straight through. Thanks for the help
Old Sep 22, 2009 | 04:23 AM
Calypso's Avatar
It took me and a buddy about 5 hrs of working steady but not in a hurry.
Old Sep 22, 2009 | 05:25 AM
c90dan
Guest
Posts: n/a
I installed the Teraflex 2.5 with shocks by myself. Took about 8 hours. It's not difficult, just a lot of work. I didn't do track bars and I have air tools. The lift use will help a lot! Have fun.
Old Sep 22, 2009 | 05:36 AM
wayoflife's Avatar
JK-Forum Founder
if this is your first time at it, expect it to take about 6-8 hours. if you have all the right tools, know exactly what to do, divide up the work and work efficiently, you can easily get it done in half the time.
Old Sep 22, 2009 | 05:37 AM
09rubicon's Avatar
I have installed three TF 2.5" Coil lifts so far. It takes about 4-4.5hours by yourself, a little faster with a friend.
Old Sep 22, 2009 | 05:40 AM
Ben Hedrick's Avatar
Good advise and I would add; "read the TeraFlex instructions twice before starting...and follow their format and process to the T!!!!
It took me about 4-5 the first time and 3-4 hours the second time. Good luck, Ben
Old Sep 22, 2009 | 05:50 AM
wayoflife's Avatar
JK-Forum Founder
also, if you haven't already seen it, this write-up should help you out some:
http://project-jk.com/jeep-jk-write-...ation-write-up
more help can be found here:
http://project-jk.com/jeep-jk/jeep-jk-write-ups
Old Sep 22, 2009 | 07:08 AM
Thanks for all your imput
