Install winch warn 9.5xp
Old Jan 23, 2010 | 07:16 AM
remi987's Avatar
Default Install winch warn 9.5xp
Hello,
I just receive my Shrockworks bumper and I want to install my winch Warn 9.5xp on it.
But when I open the box of my winch, there have a yellow sheet that's write :
Important notice
9.5XP winch feet forward mounting
When mounting the 9.5XP winch feet forward refer to the illustation below and follow the instructions for removing and replacing the sealant for motor drain slots.
I don't know how remove motor from drum support... And does this step is necessary ??
And I have an other problem. I have the bracket for installing the console on the winch, but I don't know where put this bracket on the winch... ??
Anyone can help me please !?
Thank you !
Old Jan 23, 2010 | 09:56 AM
remi987's Avatar
Now I found i don't have to remove motor from drum support. So that's ok for that.
But I don't find a place for fix the bracket and fix the console on my winch.
There is picture of winch and bracket... : http://s721.photobucket.com/albums/w...20Shrockworks/
And it suppose to be like that : http://www.hummer-performances.com/a...EEL_aXm2JM.jpg
Old Jan 23, 2010 | 10:28 AM
zoeydad's Avatar
I have one of those winches, but it's been a while since I did the install. If I remember correctly, the bracket is mounted on the winch by removing one of the allen bolts from one of the support rods (the silver bar running across the top of you winch).
I took my solenoid box apart and installed the controller connector in the glove box and the solenoid box itself in front of the battery. I had to remove the plastic cover from the box, and I wrapped it in rubber sheath.
Old Jan 23, 2010 | 11:40 AM
remi987's Avatar
Thank you ! that's work now !!
