Installation of arb diff covers
Old Oct 4, 2012 | 03:18 PM
Gman*2007's Avatar
Default Installation of arb diff covers
I'm istalling these covers with the lube lock gaskets & I have the bolt tightening pattern but my question is "Do I use locktite on the bolts and what should they be torqued to?
Old Oct 4, 2012 | 03:37 PM
azxr's Avatar
I just did my Riddler covers with lubelocker. I didn't use locktite and didn't see any mention of it, but I guess it wouldn't hurt to use a mild version. Anyway following their tightening pattern, I did 15 lb-ft first time and then 30 lb-ft the second time around. I think their instructions say 35 lb-ft but that is too much and is different from all of the other references I have seen.
Old Oct 4, 2012 | 03:40 PM
river2c's Avatar
Do not use thread locker or you risk breaking the bolts off when you try to remove them. You can use anti-seize if you want. The bolts don't have to be very tight. Torque no more than 25-30 ft/lbs.
Old Oct 5, 2012 | 08:06 AM
Gman*2007's Avatar
I appreciate the info gents
