Installed CROWN Brake Lines Do They Look OK
Old Jul 4, 2008 | 10:53 PM
JK07's Avatar
Default Installed CROWN Brake Lines Do They Look OK
Just replaced factory Brake Lines with Crown brake lines. They are supposed to fit between 3" to 4" Lift. I am just a bit nervous. They look too long to me, Can some please advise if they are OK.
Old Jul 4, 2008 | 11:34 PM
Audiophiliac's Avatar
Looks fine. I have had mine on for a while and have been wheeling twice and no problems. I also re-ran the rear ABS lines to get more slack.
Old Jul 4, 2008 | 11:45 PM
Mutts08JK's Avatar
Has anyone thought of making there own brake lines. I have access to a limited supply of Parker Hydraulic hose that has a burst rating of 6000psi. and was wondering that if I can make my brake lines that exceed DOT ratings would it still be legal to run on the roads?
As for the lines they would need to be long to aloow for the articulation of the axle from full stretch to compression.
Old Jul 5, 2008 | 03:55 AM
WifesaJPgirl's Avatar
Yes I have made my own brake lines before, but no they are/were not DOT legal. In order to comply with DOT standards the brake line has to has some anti-whip built into it. All that means is the line wont bend so severe that it stops fluid flow.
As far as the hyd. hose, as long as it is rated to brake fluid and has at least a constant perssure rating od 2500psi, it should be okay. Personally I wouldnt use anything other than teflon lined steel braided "brake hose", its just not worth the risk if something goes wrong.
Old Jul 5, 2008 | 09:51 AM
easttnruby's Avatar
Those are sweet. where did you find those?
Old Jul 5, 2008 | 10:19 AM
Rubimon's Avatar
Is your Jeep upside down, reversed, built backwards????????
Old Jul 5, 2008 | 10:20 AM
Mutts08JK's Avatar
The Parker Hyd. Hose exceeds DOT standards and has a +3000psi continuos pressure rating with a burst rate of +6000psi. can withstand dot3,4and5 fluids in them and multiple other fluids.
2K1TJ's Avatar
I think Northridge sells them.
Edit:
Yep, here they are (click)
Old Jul 5, 2008 | 01:25 PM
kidjeep's Avatar
Based on the fact that the post comes from Australia, it is probably a right-hand drive JK.
Old Jul 5, 2008 | 07:00 PM
JK07's Avatar
Yep its a right hand drive.....
