Installed JKS discos
Old Dec 19, 2010 | 12:45 PM
PainKiller's Avatar
Default Installed JKS discos
Just installed the JKS quicker discos a few weeks ago and it seems i might not have set it up right i hit some rough spots going through an intersection last night and I had a bad wobble in the front end, so then i slowed down and it about shook the steering wheel out of my hands. After coming to a complete stop and then taking off again it didn't do it the rest of the night. any advice from someone that has installed these on their rigs ? thanks
i also installed the woods stabilizer shock bracket the same day as the quick disco's
Old Dec 19, 2010 | 01:04 PM
nthinuf's Avatar
Sounds more like something is loose than anything to do with the discos. Break out your torque wrench and see what you find. Start with the trackbar...
Old Dec 19, 2010 | 01:35 PM
mkjeep's Avatar
When you installed the Woods SS relocate bracket, you have to take the trackbar loose right? As said, start there and re- torque it.
Old Dec 19, 2010 | 04:01 PM
ronh911's Avatar
2X-Track bar
Old Dec 19, 2010 | 06:42 PM
jeepmedic's Avatar
Sounds like someone has a case of the death wobble. As everyone stated, check the track bar. If that doesnt help just search "death wobble" and youll find hours of reading.....
Old Dec 20, 2010 | 06:54 AM
AlexjeepVb's Avatar
What size tires do you have?, re-tighten everything under the front end, but i have 35's and i get a slight wobble every once in a while with everything tight
Old Dec 20, 2010 | 07:29 AM
JayhawkJeep's Avatar
Veteran: Navy
Agree with everyone and check your track bar.
Just to be certain what length discos did you get and do you have a lift?
Old Dec 20, 2010 | 08:17 AM
Hellbound13's Avatar
You need to torque that trackbar bolt to 130 ft lbs. It's probably not to spec from when you installed the woods bracket.
Old Dec 20, 2010 | 11:50 AM
Red Dog's Avatar
It sure sounds like it is something other than the Disconnects. What I do some times when I am looking for some thing that is loose. I will jack up the front end and set it back down on jack stands so the front wheels are off the ground. Then start a check of every part in order so I don’t leave one out. You never know what you will find. My in-laws are in from BA to enjoy the sun and it is raining for the next couple days. They’ll live.
Old Dec 20, 2010 | 11:35 PM
PainKiller's Avatar
got the 4-6" discos. I am running a 4" rc lift and 35's
