Installed Mud tire, now it pulls to right while driving
Old Jan 23, 2010 | 04:44 PM
wolfmanii's Avatar
Default Installed Mud tire, now it pulls to right while driving
Just replaced my stock tire with good year MT/R
Now my JK pulls to right whiel driving. Goodyear dealer says they
can fix it by just swapping the front tire (left to right and vice versa).
Will it work?
Old Jan 23, 2010 | 04:56 PM
horwitzs's Avatar
If they'll do it for free it's worth a try
Old Jan 23, 2010 | 05:34 PM
The Jeep's Avatar
Maybe you did this but if you didn't check your tire pressure.
Old Jan 23, 2010 | 07:11 PM
Ryanc's Avatar
Mine do it too.
Old Jan 23, 2010 | 07:22 PM
bikehudson's Avatar
swapping may work. Radial tire pull is a fairly well known phenomenon and tends to be more pronounced with MTR's. This has solved quite a few peoples pull.
Old Jan 23, 2010 | 08:04 PM
wolfmanii's Avatar
I don't quite understand the theory that swapping can solve the problem.
I looked at the tread pattern, after swampping, the pattern is exactly the same.
I am just thinking that after swapping, it may pull to left side.
Anyway, I will post the result this Monday.
Old Jan 23, 2010 | 09:16 PM
wolfmanii's Avatar
Yes, I did check pressure. I even lowered driver side tire pressure a little bit mor
hoping it will cover the problem, but no luck
Old Jan 23, 2010 | 09:20 PM
nangulator's Avatar
Swapping right to left should fix it, sounds like a radial pull.
Old Jan 24, 2010 | 05:24 AM
Ryanc's Avatar
My theory is that most of us have some negative camber in our axles, you jack that thing up and put some bigger meat on, the effect of camber is only amplified.
Old Jan 25, 2010 | 04:48 AM
wolfmanii's Avatar
Front Tire swapped today, still the same thing, pull to the right.
