Installed Rancho Geometry Correction Brackets
I had a question about how to re-attach the lower control arms after installing the brackets. While installing them it seems my axle rotated and I lost about 2" of length and could not figure out how to re-attach the lower arms. I search for about a hour on how to twist my axle so they would re-attach and couldn't find anything.
I ended up putting blocks in front of my front tires and drove the jeep into the brackets. This seemed pretty dangerous but I was desperate. It was dark already I need to drive in the morning. What was I supposed to do? |
I used a ratchet strap to pull mine back in place |
I found the easiest way to do it is put your jeep in neutral and have a buddy roll the tire of the side you are installing while the opposite side is wedged or chalked. You can do it solo but really easy with a helper. I have installed no less than 10 sets of these and have used ratchet straps too but just rolling the tire is easier or has been for me.
You should be able to get things lined up with a well placed jack at the differential, jack at pinion to decrease distance, jack at cover to increase of that makes sense.
Originally Posted by Jahamm88
(Post 4318614)
What you did does indeed seem dangerous. Count yourself fortunate. |
You get it handled? Pics?
(Post 4318614)
Floor jack under the diff. You can do it solo too. |
(Post 4318614)
Here's a LCA install video that describes the concept pretty well. However, he describes to put the jack on the tie rod end to increase distance. |
