Installed rear upper adjustable arm noise
Old Oct 28, 2014 | 08:16 AM
Dus10's Avatar
Default Installed rear upper adjustable arm noise
First off, I have an 07 2 door jk with a 4 inch lift.
I installed rear uppers about a week ago to fix drive shaft pinion. Everything has been fine until on the way to work this AM I stated hear a grinding noise like something is dragging. Metal to metal. Only happens when I'm moving, did a quick look under jeep and didn't see anything obvious. When I get home from work I will go more in depth just wanted any ideas you guys might have. I am a JK newb, Sold the YJ.
Old Oct 28, 2014 | 08:19 AM
Invest2m4's Avatar
Do you have an aftermarket rear driveshaft? The stockers are designed to be run at an angle. If it's a stock shaft and original, running it straight on probably sent it to its death.
Old Oct 28, 2014 | 04:11 PM
silversurfer575's Avatar
What brand of upper adj control arms did you go with?
The arms themselves should not cause a grinding noise as they should not come in contact with anything moving.
Old Oct 29, 2014 | 07:43 AM
Dus10's Avatar
There are rubicon express. I pulled them off last night and put the stock ones on. No noise, I think one of my rear brakes was dragging?? Now it's fine though?
