Installing Driving Lights
Old Jan 30, 2008 | 07:24 AM
AirBoyzT's Avatar
Default Installing Driving Lights
Ok im about to install my Hella 500s and was wondering is there a place to put switches in the JK.
Thanks
Old Jan 30, 2008 | 07:32 AM
wayoflife's Avatar
JK-Forum Founder
Thanks
There is plenty of room on the easily removed plastic plate on the center part of your dash, just in front of the shifter.
Old Jan 30, 2008 | 07:42 AM
AirBoyzT's Avatar
Those are already filled with axle lock, sway bar disconnect, ESP Off and other buttons that came with my jeep...
Old Jan 30, 2008 | 08:03 AM
StuDad's Avatar
i put mine (and a lot of other dudes did too) to the left of the wheel, above the speaker. A big plus for that is that it's really easy to get to, and to get wires to.
Old Jan 30, 2008 | 08:06 AM
AirBoyzT's Avatar
did u drill a hole for the switch or did it just fit in?
Old Jan 30, 2008 | 08:24 AM
Dropkick's Avatar
I think he means in that big blank plastic area below where the current buttons are located.
Old Jan 30, 2008 | 08:28 AM
AirBoyzT's Avatar
oh gotcha, wouldnt that require cutting out an area for the switch?
Old Jan 30, 2008 | 08:32 AM
Dropkick's Avatar
Yes. Or, I've seen some threads where people have installed an entire switch array in that area. I don't remember what it was called, but it allows you to add 4 or 5 switches all at once, and only cut one new hole.
Old Jan 30, 2008 | 08:33 AM
markmbsc's Avatar
I think Daystar makes a panel with switches that will replace that blank panel. I know I've seen them on ebay.
Old Jan 30, 2008 | 08:36 AM
AirBoyzT's Avatar
something like this??
or this...
http://www.quadratec.com/products/12500_231.htm
