Installing IPF 901xsd driving lights to a S-pod
First off, I have no idea what I am doing. I want to install the IPF lights to my S-pod and have the ability to run the lights whenever I want with a flip of the S-pod switch. The wiring harness from the IPF's have built in relay/fuses, which to my understanding I don't need/ shouldn't use with the S-pod. Do I need to get a new wiring harness or modify the harness to make it work? Also do I still need to tap into the high beams to make the lights work with the S-Pod? Any help would be much appreciated! Thanks
All you need to do is cut the wiring harness before any relays or fuses. You just need a positive and negative wire to run directly to the sPOD control panel and you're set. Just pick a slot that has the right amperage in the control panel. Default I believe 3 are 15A and 3 are 20A from the manufacturer. I can't recall and I'm too lazy to go down into the garage.
