Installing jks rear track bar bracket or no bracket
Old Mar 18, 2017 | 08:27 PM
Dunejk13's Avatar
Default Installing jks rear track bar bracket or no bracket
So my Question is my jk has a teraflex frame side track bar drop bracket should i keep it or remove the and install the jks bar
Old Mar 18, 2017 | 08:48 PM
sa29560's Avatar
Seems like most are running an axle side bracket.
Definitely run one or the other, not both.
Old Mar 18, 2017 | 09:56 PM
nthinuf's Avatar
No problem running both, assuming the adj trackbar can shorten to stock length. If you remove the bracket, you may notice a bit more body roll due to the new steeper angle. Most here seem to prefer a bracket raised from the axle rather than dropped from the frame.
