Installing MORE BL, Anything I Should Know?
Old Apr 8, 2008 | 07:22 PM
nukeman's Avatar
Default Installing MORE BL, Anything I Should Know?
I'll be installing a MORE 1" Body Lift on my Unlimited Auto this weekend. Any helpful tips you guys can pass along? Any mods to the shifters required? Thanks.
Old Apr 8, 2008 | 07:24 PM
brianb1222's Avatar
Make Sure You Loosen The Opposite Side Enough So It Will Come Apart.it Is Really Easy To Do.
Old Apr 8, 2008 | 07:35 PM
mkjeep's Avatar
Use a screwdriver the pull down on the washers while you take the bolts off, there is a retainer washer between the mount and the bolts will loosen so far until that washer stops them. Just keep steady down ward pressure and no probs.
Old Apr 8, 2008 | 08:13 PM
badbu79's Avatar
Pray the factory did not cross thread the back bolt and you break the weld. It added about an hour to the project
Old Apr 8, 2008 | 08:19 PM
gooseau's Avatar
Default hint
Easiest thing in the world to do, but don't do it late at night like I did because you will have the cops show up wondering why there were loud beating noises coming from the garage when I was taking off the washers. They were a bitch.(The washers of course)
Old Apr 11, 2008 | 05:56 PM
nukeman's Avatar
Dumb question, do you absolutely have to remove the grill to remove/install the front mounts? I'm asking because my winch is within 1/8" of the grill and removing the grill is now officially a PITA. Any way around it would be great.
