(: Installing River Raider Skids on 2012 and have a torque question :)
Old Feb 11, 2012 | 12:33 PM
SpaceMonkey's Avatar
Default (: Installing River Raider Skids on 2012 and have a torque question :)
Will soon be installing the full river raider skid system in aluminum and I see the instructions call for mounting the oil skid to the engine motor mounts. Does anyone know what the proper torque numbers are when tightening them back up? Much appreciated.
Old Feb 11, 2012 | 12:46 PM
Rich6700's Avatar
You can never go wrong with, good and tight. Seriously, good and tight will do just fine.
Old Feb 11, 2012 | 12:48 PM
Ha.. Yeah but my good and tight has a history of good and snapped :(
Old Feb 11, 2012 | 12:53 PM
Rich6700's Avatar
I didn't say use a breaker bar on it. Use your judgement, a quarter turn after the nut tightens should do it.
Old Feb 11, 2012 | 01:08 PM
I gotcha... I have been improving, but always have that "humm was that enough".
Old Feb 11, 2012 | 01:27 PM
SH0RTBUS's Avatar
What size are the bolts? Torque should be based on bolt size and material. From there you can google up a torque table. Good and tight is bad, unless your talking about your girlfriend.
Old Feb 11, 2012 | 01:34 PM
I believe they are M10 and M12
Old Feb 11, 2012 | 01:49 PM
SH0RTBUS's Avatar
Here you go. Use "lubricated" value if loctite is used. http://www.cncexpo.com/MetricBoltTorque.aspx
Old Feb 11, 2012 | 01:53 PM
jason0341's Avatar
I don't know for sure of the motor mount torque specs are in here, but it might be worth a shot to check through it.
http://project-jk.com/jeep-jk-write-...orque-settings
Old Feb 26, 2012 | 07:09 PM
eatoftexas's Avatar
I had the same question, installing a Skid Row engine skid plate, and some other threads said that the torque on the bolts on the motor mounts is 45 ft lbs. Good luck on getting a torque wrench in there, though.
