interior lighting question
Old Dec 26, 2013 | 03:23 PM
mscotthall's Avatar
Default interior lighting question
Hi everyone,
This evening, i was attempting to add some extra lighting to the interior of my 2012 jku sport. I ran wire and hooked some of the extra LED lights to the dome light wire located in the passenger foot well. Everything was going perfectly, but then, for some reason the dome lights stopped working. I checked all of the wiring, bulbs and switches. My assumption is that I blew a fuse... but, I can't seem to find the fuse for the interior lights. I couldn't find anything with that label on the inside of the fuse box cover. Any help would be greatly appreciated.
Old Dec 26, 2013 | 03:38 PM
ronjenx's Avatar
The dome light's driver is in the cluster, no fuse involved according to the wiring diagram.
Is your dome light an LED, too?
Check for voltage at the lamp socket. If none, check on both sides of any splices you made.
Old Jan 2, 2014 | 02:19 PM
Joker's Jk's Avatar
Did that fix your issue? I'm researching before I start adding LEDs.
joker----- Sent from my iPhone using JK-Forum
