Issue with a new u-joint on my rubicon express drive shaft... Anyone else?
#22
#23
#28
So i just want to make sure that i am getting all the right info... Probably the reason my u-joint went out and the ball in the cv-joint went is because i have a 3.5" RE standard kit with stock control arms? AND i should get my adjustable lower front control arms to fix the caster and get a new shaft?
#29
#30
You need to know what your pinion angle is.
Caster is #2 when running a aftermarket shaft.
With stock arms you probably are Ok.
Currently a am running TF lowers adjusted all the way in which is at or close to stock length.<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=422683"/>
