Issues after long tube installation and cat deletes
So this all started by a faulty cat....it broke off inside the chamber on bank one side upstream cat....I've always delt n muscle cars and this is my first jeep so I naturally thought more breathability better performance so I got a set of pacesetter long tubes and the offroad pipe combo.....as soon as the install I get a code for bank 1 sensor 1 so I change it...everything g was good for a few days....then engine light comes back on and now its p0420 and p0430...that's understandable bc no cats....then it starts running extremely rich and codes p0171 and p0174 come on so I installed some non-fowlers on the downstream 02sensor and cleared the codes....Its still sputtering on mild acceleration and I'm out of ideas....any suggestions???
I have never actually hear of someone going through the exhaust like ya did... Soooo i have no idea :rotflmao2:. Maybe go back to stock. If its performance you are after get a Prodigy Turbo kit.
Originally Posted by DEJK2012
(Post 4339834)
:rotflmao2: looks like my advice is best so far, you are welcome :thumbsup:
How do you know it's running rich? Are you monitoring the AFM? The two codes (p0171 and p0174) are why the engine is fattening the AFM... the computer sees the report from the sensors that the exhaust indicates a lean engine so it then fattens the AFM. Purchasing non-fowl O2 sensors doesn't do a thing to fix this.
Have you checked for vacuum leaks after the throttle body (really after the MAF sensor)? Low fuel pressure? Leak in the exhaust prior to the O2 sensors? |
The fowlers were for the p0420 and p0430 codes together....I've checked for vacuum leaks with no luck...I removed my pcv hose and found some oil so I replaced the valve yesterday and removed and cleaned egr valve.....fuel system is next on my list but I really feel its sensor related bc when I reset codes and run it at idle until abt op running temp it runs great with no stumbles but when I hav to jump n and go it will begin to act up slowly which has me thinking open loop vs close loop operation....I've searched everywhere to see if a tune is required for exhaust mods but I've found nothing
Originally Posted by Easye33
(Post 4340098)
Also, the non-fowlers don't fix your issue, they would have just masked it. |
Originally Posted by jedg
(Post 4340101)
You just said it yourself. Open vs closed loop. The system doesn't pay attention to many of the sensors (for sure not the O2 sensors) so the jeep may run fine initially.
Don't you have another thread asking similar questions? I think in that one, you're asking the same question in a different way.
Like I said before. Your computer is getting information that you're running lean. That's either a problem with what the O2 sensors are reporting or what the MAF is reporting or you have air entering the system between the MAF and the O2 sensors. What's your A/F ratio? And, really, I don't see what you think you are gaining with cat delete. It's not like the 3.8L horsepower is limited by the exhaust. |
(Post 4340708)
