Jack carrier
Old May 17, 2008 | 07:05 PM
JK7349's Avatar
Default Jack carrier
Does anybody know where I can find a High lift jack carrier that bolts to the OEM spare tire carrier?
Old May 17, 2008 | 08:35 PM
MattMac1291's Avatar
http://www.4wd.com/productdetails.aspx?partID=41258 here ya go .... i was thinkin about it myself but decided to get the mounts and put it on the front bumper
Old May 18, 2008 | 04:40 AM
riverzendz's Avatar
Here's one for you but like Oleg said, you wouldn't want to use it on the stock carrier because of the weight concern.
I picked the mount up from a guy on ebay. It's pretty decent and ran me $39.99 shipped. I had to specify JK so he could drill it 5 on 5. He sells mostly 5 on 4.5.
It does rock side to side a little bit but it's an easy fix. There are two pieces, one that mounts behind the spare and one that slides into the other half. It's held together with a pin and the pin is too small which allows the motion. I plan on drilling it out to 1/2" and putting a better pin in to keep it from moving. Here are some more pics of the mount and the good thing is, it'll work on the stock tire carrier too.
Nothing to do with JKS. I through that on there because it was laying around and had nothing better to do with it.
Old May 18, 2008 | 05:54 AM
flyer415's Avatar
Hey, is that a normal 2" receiver size. I am interested in knowing if I could use it to hook up my cargo basket. I would not use the end plate just the receiver part that bolts on to the carrier.
Old May 20, 2008 | 02:51 PM
JK7349's Avatar
Thanks for the info guys!
Old May 21, 2008 | 05:43 AM
[N]UGE's Avatar
that looks like a good product. Its nice to have it centered on the back.
