Jeep going crazy!!!!!
Old Aug 24, 2013 | 03:48 AM
Shearlow's Avatar
it may also be your TIPM, mine went nuts last year, lights, horn/alarm, wipers/washers all going crazy! flashing honking and wiping... engine cut off as well. Just something to consider.
Old Aug 24, 2013 | 06:18 AM
Spencer4336's Avatar
Originally Posted by jeeeep
How long have you had your dual setup? maybe something worked loose and shorting out, hence the alarm going off. while you are checking and possibly cleaning the terminals (not likely with only 16K miles) install your isolator.
I have had my dual battery setup for about 4 months and that's what I am thinking about something shorting out. I'm definitely going to try to install the isolator this weekend.
Old Aug 24, 2013 | 06:20 AM
Does that sound normal on a 2012 like that's no exactly what happened to mine but that's pretty close I just hope all the systems to go wacko on me when I'm driving it on the highway.
Old Aug 24, 2013 | 07:06 AM
Shearlow's Avatar
mine started off with the wipers giving just a twitch when I'd shut the door, then it got to the point where when I hit a bump it would cycle the wipers and honk the horn... and the. it just went crazy on my way to lunch one day with everything going nuts! Mine is an '08 so I don't know if they are using the same module in the newer models or not, but it was a dealer only item that had to be installed by them because it required reprogramming of the module once installed. You can try and test it by popping your hood and finding the module, on mine it's a big black box on the pass side, feel it, it may be really hot first thing in the morning. Turn on the key and go check it again, tap it a few times... the dealer did all of those things to troubleshoot mine after I had already diagnosed it for them... when mine would act up I could open the hood and hit it and it would stop. Best of luck!
Old Aug 24, 2013 | 12:51 PM
I drove my jeep around today and it hasn't gone crazy on my but on my way home my interior lights were on but they weren't switched on and no doors were open so now idk if I'm going crazy as well???
Old Aug 24, 2013 | 01:20 PM
flatattack's Avatar
I had the same issue, definitely worth a look.
Old Aug 24, 2013 | 02:21 PM
jeeeep's Avatar
for some troubleshooting I'd disconnect the accessories and run a single battery to see if the gremlins still exist...
