Jeep jk hub going bad
When I park my jeep on a decline my tires lean In in the top but if it's on flat ground they appear normal alignment shop said that the camber was -.6 and -.1 but I feel like it is wheel hubs no noise or anything coming from them do
Have a wobble at around 60mph
Tires don't seem to be loose or shake
Ball joints and tie rods just replaced also track bar just replaced also
Any help would be appreciated
Now you are saying -0.6 and -0.1.
Which is it??
It has also been mentioned it's normal for the front tires to lean in at the top.
If you think the hubs are bad, jack up each front wheel, grab the tire top and bottom, and try to wiggle the wheel. If it has no play, and is quiet when you spin the wheel, it's most likely a good hub.
