Jeep wanders since tire upgrade
Just went from stock tires to 35" trail grapplers on 18x9 XD addicts. Now it wanders and follows ruts in road real bad to where I have to really concentrate to keep it between the lines. No issues with stock tires so I have to assume its the new tires. Is it the width? Air pressure? Or do I need adjustable controlling arms I keep hearing about. Thx.
Send from my Droid using Tapatalk
You're going the wrong way, refer to the suggestions above.
Also I heard you can't align jk's without adjustable control arms or cam bolts. Ant truth to this?
You will need adjustable trackbars to center the axles.
Either adjustable control arms or the dreaded cam bolts to adjust the caster.
And adjustable ball joints to adjust the camber.
Might need to adgust your tow-in also. Heres a write up on how too.
http://project-jk.com/jeep-jk-write-...-end-alignment
