?? Jerry cans
Old Jun 7, 2010 | 05:46 PM
jtjk's Avatar
Default ?? Jerry cans
so iv searched everywhere for an easy solution to store jerry cans but cant seem to find one. seems like the only way is to buy a roof rack or a rear bumper with mounts. these seem like pretty pricy solutions to hold a 50 buck jerry can.
any one worked something out ?
thanks
Old Jun 7, 2010 | 05:51 PM
warlord's Avatar
im in the same boat as you
if you bought the 5 gallon version your options are a bit more limited.
i was trying to find a way to mount them im the side but they are too thick and would stick out too far.
ive seen one person mount it low by the spare (not the rack that holds the 2 cans like wayoflifes) but lower like it was resting on the bumper.
but either way your probably going to have to fab something up yourself
Old Jun 7, 2010 | 07:34 PM
rynokid's Avatar
this may help?
https://www.jk-forum.com/forums/show...-on-Spare-Tire
Old Jun 7, 2010 | 08:30 PM
Hellbound13's Avatar
Or this..
https://www.jk-forum.com/forums/show...ight=gas+mount
Old Jun 8, 2010 | 02:19 PM
jtjk's Avatar
thanks, that is exactly the type of thing i was looking for. only worry with this is how will the tail gate hold up with the weight?, i already have a 60 inch highlift jack mounted on the back.
Old Jun 8, 2010 | 02:23 PM
GoodysGotaCuda's Avatar
Jack on the hinges or on the gate? Full jerry is 25lbs or so?
Old Jun 8, 2010 | 02:48 PM
Arrogantbastard's Avatar
I saw a JK at a 4X4 store that had a Jerry mounted on both fron 1/4 panels that looked very very cool... I dont know how it was done though. Maybe he fabbed a hanger that goes over the lip of the engine compartment, under the hood. I think the walls of the 1/4 panel would be too weak to hold a loaded Jerry Can with just rivets or screws.
Old Jun 8, 2010 | 02:56 PM
jtjk's Avatar
on the gate, it is the rampage high lift jack mount.
Old Jun 8, 2010 | 02:58 PM
jtjk's Avatar
was thinking about just using a rack like the warrior hitch mounted rack with 8inch rise but dont know how much this would get in the way when offroad. what do u guys think, would it be a problem? ....im not rock crawling more overlanding.
Old Jun 8, 2010 | 05:38 PM
Seen one of those break in three different pieces with a 48" jack on it. Keep an eye on all that plastic, cheap bolts and thin metal retaining the upper part of the jack...
