jet chip stage 2
presently running
k&n pannel filter air aid throttle bidy spacer magnaflow cat back jet chip stage 1 and am getting between 13.5 and 14.5 l/100km hwy will be switching to a jet stage 2 when it arrives will post new numbers but my real question is i heard or read somewhere that I must change my stock thermostat to a 180 degree is this really needed or if I don't will it mean that my fan will just run more often |
Do you have to run premium fuel on a stage 2 chip?
you're supose to
will try 87 oct and 91 oct and 94 and post the numbers |
Your wasting your money on a stage 2 chip, your jeep does not meet the requirements for that chip. The stage 2 chip is for high performance engines. The 180 thermostat is required because the engine timing is cranked up, hense the engine is going to run hotter. High octane gas is needed to stop detination.
Originally Posted by retired
(Post 718281)
and in the details it does say to use a 180 degree thermostat Product Details Stage 2-Designed for the performance enthusiast, the Stage 2 features more aggressive programming to make the most horsepower and torque available. Fuel and timing curves are extensively modified for peak performance and drivability. Requires use of 91 octane fuel, 180 degree thermostat and free flow exhaust. Also works well with aftermarket intake systems, mass air sensors, TBI spacers, etc. The JET Performance Module for Dodge, Chrysler and Jeep vehicles is a JET exclusive. Dynamic Spectrum Tuning provides power gains across the entire power band-not just at full throttle. Point by point air/fuel ratio, ignition advance and various other tuning points provide performance gains of up to 25 horsepower. Improves throttle response, acceleration and low end torque. Simple, plug-in installation in less than 30 minutes. |
(Post 718281)
What more is needed
this is all that is required as stated on quadratec |
Headers, free flowing exhaust, high performance intake manifold. And most of the horse power made with the stage 2 chip is in the upper rpm range. Stick with what you have!
You can expect MPG to go down and throttle response to go up! Horsepower will not be that noticable over the stage one. By the way you will get the same "basiccly" performance by getting a hypertech and you can switch between stock, regular and performance tuning as well as OBDII code reader tire size adjustments thermostat settings gear ratios etc. I would not advise springing for another 300.00 jet chip. But if you are set on it i would like to see your numbers. hopefully it will not take you down to 13mpg though.
| All times are GMT -8. The time now is 10:31 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
