Jet ski anyone??
I'm getting a new jet ski this weekend and this is the first time me haveing one with a wrangler jku 4 door. Could anyone tell me how good of towing it does and if the weight is to much 1600??
I hauled two three seatters just about 300 miles (from Sioux Falls SD to Minneapolis MN) with a fully loaded JKU, a little trouble going uphill against the wind on the interstate, but then again I have that trouble when I’m not pulling anything
but other than that no problem.
If you tow for a long distance just make sure you have 75-140 gear fluid in your rear diff as recommended in the owners manual, otherwise Jetski's aren't that heavy so you should have no problem
Hey guys I'm new here and planning on grabbing a '13 sport unlimited. The model I'm looking at comes with the "reg" tow pkg with 3.21. I have a 2012 sea doo which is on the heavy side (bout 1200lbs) when gas filled. My question is should I push for "max" tow pkg with 3.73 or is reg ok?
I pull an 18 foot runabout with zero problem. 4.10, 3.6 auto. I believe total weight is around 3,000-3,400 with trailer. Trailer has brakes which I expect helps. I towed it around two hours each way last weekend. No problems.
