JK 44 unit bearings
Old Dec 17, 2008 | 08:38 AM
jkkat's Avatar
Default JK 44 unit bearings
Hi Guys and Girls,
I have already gone through 1 set of unit bearings on RubyDoo and now the right is going again. Is there anything better than stock or is there anything i can due to make these last longer?
Old Dec 17, 2008 | 08:40 AM
Northridge4x4's Avatar
Sponsoring Vendor
Only a spyntech kit.
David
Old Dec 17, 2008 | 08:47 AM
rocknredrubi's Avatar
How do you know when your unit bearings are going?
Old Dec 17, 2008 | 08:49 AM
jkkat's Avatar
lift up the front with a floor jack and if the top of the tire can move from inside to outside its the bearing or loose lug nuts.
Old Dec 17, 2008 | 09:10 AM
09rubicon's Avatar
Dumb question, but how often do you repack them? Sealed or not bearings need lube and lube breaks down with heat/pressure/contaminants. You may be at the point that you have to replace them, but on the next set try altering your maintanance to tear down, clean, repack the bearings every 10-15000 miles or sooner depending on how hard you are on them.
Old Dec 17, 2008 | 09:33 AM
Sponsoring Vendor
Unit bearings are non serviceable. You can not grease them sorry.
David
Old Dec 17, 2008 | 11:14 AM
Piginajeep's Avatar
how much are you paying for unit bearings?
Old Dec 17, 2008 | 11:54 AM
jkkat's Avatar
Just over $100.00 a piece. First set was done under warranty just before the 35's went on.
Old Dec 17, 2008 | 01:59 PM
ronjenx's Avatar
When I had my XJ, the front bearings (unit bearings) went out at 30k miles. They were expensive enough to have them replaced that I used the money to buy two sets of bearings, the factory mandrel kit, AND a 20k lb. press and fixed them myself. My point being, I discovered the bearings from the factory were a Japanese brand. I bought Timken Bearings and never had a bearing go out after installing them. I sold the vehicle after 14 years and 180k miles.
If people are noticing front wheel bearings going out early, maybe the same thing could be done.
Old Dec 17, 2008 | 02:35 PM
Writeup.... Anyone?
