Jk brake fluid!!!
hey what D.O.T is the factory brak e fluid???
when changing brake lines do you sugest to use the same one or its better a new one???
is there a better one than the factory??
as posted above:
DOT 3 Brake Fluid, SAE J1703 should be used. If DOT 3, SAE J1703
brake fluid is not available, then DOT 4 is acceptable. Use only recommended
brake fluids.
The maintenance schedule doesn't mention flushing the system. Doing so every two years will prevent system corrosion and other problems.
brake fluids.
as posted above:
brake fluids.
brake fluids.
, I gave him the cliff note version.
edit to add:
A google search reveals it also means the hose must be compatible with Brake Fluid SAE J1703, which includes DOT 3.
I know it's your thread, but start another one. You'll get more info on Rock Sliders.
