Jk pulls left and not sure why
Old Mar 6, 2013 | 01:16 PM
natebri2575's Avatar
Default Jk pulls left and not sure why
I need a little help cause this is driving me nuts. I have an 08 jk 2 door. 4" skyjacker lift, 35s mickeys, adj control arms, front and rear double cardon shafts, skyjacker double ss. I notice a slight pull to the left while driving. Wheel looks a straight. No uneven tire wear. Alignment good. It seems like the pull is more prevalent since recent tire rotation and balance. This is making me crazy. No major offloading lately either. Please help.
Old Mar 6, 2013 | 01:26 PM
frantic puppets's Avatar
How bad is the pull? Does it pull at all speeds, or is it more noticeable at high speeds?
Does it happen more when accelerating (and then push back right a bit when letting off the gas)?
Old Mar 6, 2013 | 01:56 PM
It might get a little worse at high speed. It's a subtle pull left. Not hard. I haven't noticed it when accelerating but it seems like it does pull when braking.
Old Mar 6, 2013 | 02:01 PM
Ill check when accelerating. One thing , if I let go if the wheel it will go straight then it's almost like I go over a bump or road crown and it will drift?
Old Mar 6, 2013 | 02:10 PM
finfreeze's Avatar
Have you checked your tire pressure?
Old Mar 6, 2013 | 02:39 PM
That was the first thing I did. I've heard rumors that the double ss could do it but I don't understand why. With a skyjacker shot there is no pressure pushing one way.
Old Mar 6, 2013 | 05:32 PM
Any ideas?
Old Mar 6, 2013 | 05:41 PM
Ncb's Avatar
Ncb
If it started or got worse after a tire rotation/balance it's probably a tire issue. Swap fronts and rears and see if it stops.
Old Mar 6, 2013 | 06:05 PM
snowbilt's Avatar
Might look at the bushings/hiem joints on the control arms. May have a worn one
Old Mar 6, 2013 | 07:51 PM
I have adjustable flex LCAs on the front. I reinstalled my double ss to the exact specs to see if it helps. If not I will rotate tires again. Very annoying problem.
