jk shakes
Old Aug 16, 2007 | 06:36 PM
macdaddy69's Avatar
Default jk shakes
I crossed rr tacks and jeep started shaking very badly any reason why? left to right into steering wheel.
Old Aug 16, 2007 | 06:38 PM
Robar's Avatar
Was there a train comming?
Old Aug 16, 2007 | 06:44 PM
macdaddy69's Avatar
nope.........
Old Aug 16, 2007 | 06:46 PM
Robar's Avatar
Sorry, if I didn't ask some one else would have.
Is your Jeep stock or do you have any suspension mods, tires, wheels, and things like that?
Old Aug 16, 2007 | 06:47 PM
Buster's Avatar
Did you check your Wobble Shaft?
If it's not that, Check the steering stabalizer and all the bolts around the front end.
Old Aug 16, 2007 | 06:50 PM
Rubimon's Avatar
Need more info like stock, lift, tire, etc.
Old Aug 16, 2007 | 07:11 PM
macdaddy69's Avatar
4" skyjacker,37s didnt do it till i added 3/4 spacer and dana 44. Everthing seems tight.
Old Aug 16, 2007 | 07:36 PM
Biff Malibu's Avatar
Do you have a dropped pitman arm?
Old Aug 17, 2007 | 04:42 AM
macdaddy69's Avatar
yes.......
Old Aug 17, 2007 | 04:48 AM
xravn's Avatar
i would triple check the track bar, make sure the bolts are tight and tightened to 125lb of torque. get a friend with jeep on to turn the wheel right and left while your looking at the trackbar and see if it shifts even a little. any slight movement in the bolts makes a huge difference in drivablity and may attribute to a Deathwobble. good luck it can be a pain to track down suspension quirks. could be a number of things from tires out of balance to trackbar or bent rods. maybe even exagarated bump steer.
