Jk shift knob,
Old Jan 27, 2013 | 02:08 PM
Way2sly's Avatar
Default Jk shift knob,
This is my latest mod, to the start of many. This hear is a deactivated m228 hand grenade shift knob.
ID:	414895   Click image for larger version
ID:	414896   Click image for larger version
Old Jan 27, 2013 | 02:16 PM
PLOTTHOUND's Avatar
monday i was intending to do that to my transfer case shifter only because it seems like it would be uncomfortable to grab the grenade spoon all the time while shifting... and my regualr shifter is a 13 billiard ball. i like how it looks though. did you have to put anything in the grenade to keep it from wobbleing around since its hollow or is the metal on the bottom enough to hold it steady?? thanks for the pics man looks good!
Old Jan 27, 2013 | 02:23 PM
Way2sly's Avatar
I position the spoon just so that is not in my hand, turns out that the stock shift rod and the bottom of that grenade was only a file away from a machined inference fit, no wobble jus a tad heavy is all
Old Jan 27, 2013 | 02:55 PM
afpilot82's Avatar
JK-Forum Ambassador
I have mine turned on the side, hand fits perfectly around it.
Old Jan 27, 2013 | 03:11 PM
Way2sly's Avatar
That's a nice look to, did you just drill it's to fit or did you silicone it on, did your had a hole in the bottom
