jks quicker discos...
Old Mar 31, 2008 | 07:09 PM
airric00's Avatar
Default jks quicker discos...
Does anyone completely remove these when wheeling? Or do you bungee it to the sway bar? Any help appreciated....
Old Mar 31, 2008 | 07:22 PM
steves07jk's Avatar
Default Jks quick discos
Every time I go out I usually pull them completly off and rotate the sway bar up out of the way. What is your concerns?
Old Mar 31, 2008 | 07:25 PM
scouter4life's Avatar
Usually I just leave the links on and strap them to the sway bay. It's a lot faster and I don't have to mess with trying to bolt them back on (I'm using my rear links in the front)
Old Mar 31, 2008 | 07:31 PM
Robar's Avatar
I just got my JKS quicker disconnects, but I plan on taking them completely off.
Old Mar 31, 2008 | 08:10 PM
pe_jeep's Avatar
Be careful rotating them up out of the way, you can puncture your tire at full stuff, they are supposed to remain in a neutral position.
Old Mar 31, 2008 | 09:15 PM
airric00's Avatar
So if you're using JKS disconnects taking them completely off and keeping the sway bar neutral is the way to go? My concern is exactly as he posted... I don't want anything loose to puncture, rub or be flying around by any means.. Going on some serious stuff tomorrow that is all...
Old Mar 31, 2008 | 10:20 PM
troyboy's Avatar
Hey, what would happen if you took just one side off and left the other side on? Wouldn't that be similar to what the auto disconnect on the Rubicon essentially does?
Old Apr 1, 2008 | 07:11 AM
airric00's Avatar
Originally Posted by jkdrone
Well, sorta - the sway bar is still attached to one side. So, when you're stuffing things up and manouvering (sp?) over those rocks - where exactly is the disconnected side's pin now? Maybe it's safely outta the way, maybe it's digging into your tire?
It takes 20s to disconnect them completely. Pull four pins, pull out the disco's, wrap a bungee around the frame in a neutral position. (My bungees are pretty loose, and the bar stays in that spot.) You're done, and safe. Spend 10s and get iffy results.
!c
Well said and thank you for your information!!!!!
Old Apr 1, 2008 | 07:41 AM
AZ Bulldog's Avatar
I completely remove mine, the first few times I was worried about the sway bar getting in the way but it hasn't happened yet.
Old Apr 1, 2008 | 07:58 AM
RevyJKU08's Avatar
!c
Any pictures of the sway bar in neutral position???
