JKS Rear Bar Pin Eliminators?
Old 12-09-2010, 09:59 AM
Hellbound13's Avatar
Default JKS Rear Bar Pin Eliminators?
Can these be run on a stock JK? I read on the JKS site that they reduce shock length by .4, so is it okay to run them stock?
Also did anyone notice a difference with them installed? Right now with the bar pins I can kind of twist the shock by hand..
Old 12-09-2010, 11:57 AM
skibum's Avatar
I ran them for almost two years. Wanted to continue running them when my clayton lift was installed but the installer forgot and they got chucked with my trashed RC shocks. The biggest difference I noticed is that the clunking associated with the forever trashed upper shock bushings went away. Once the BPEs were installed I never had to replace an upper shock bushing again.
Old 12-09-2010, 12:02 PM
Thanks. Were they hard to install? How did you get the bar pins out?
Also can I run them stock?
Old 12-09-2010, 01:17 PM
skibum's Avatar
1. They were a bitch to install........hope you own a vise.
2. Bar pins damn near fall out on there own.
3. I ran them stock no problem, then with a 2 1/2" RC lift and like I said, I was going to run them with my 4 1/2" Clayton lift.
I think that the only thing they won't work with is Old Man Emu shocks.
Old 12-09-2010, 02:23 PM
THanks for the info!
Old 12-09-2010, 02:31 PM
a couple of months back i broke a barpin and messed up 1 of my shocks, so i had to get a new shock. i was on rc's website and saw that they make barpin eliminator kits and they're only $20. just ordered a set, so this doesn't happen again
Old 12-10-2010, 05:00 AM
skibum's Avatar
IMHO RC's BPE setup, while better than stock, is not even close to what JKS offers. I've got the RC setup on my daughter's TJ (front lowers) and it works OK but it doesn't preload the shock bushings the same way that the JKS setup does so I'm still periodically replacing shock bushings on the TJ. Much easier to install, and cheaper........but you get what you pay for.
Old 12-10-2010, 01:25 PM
knight1000's Avatar
So what exactly do these do? Will they make a quieter ride in the cabin (i know jeeps are never a "quiet ride")? Do the work with stock Rubi shocks and 2" lift?
Quick Reply: JKS Rear Bar Pin Eliminators?
