JKS trakbar broken?
I'll apologize in advance for not having pics as its dark out right now, so ill get them in the morning.
So anyway today I noticed while under the rear end of my jeep my rear adjustable JKS trackbar has allot of play right where the threaded rod end meets the tube end of the trackbar. Somehow the jam nut had worked its way loose and I was unable to tighten it all the way back down on the tube end of the trackbar. So im assuming this thing is shot.
Also, its probably unrelated to my problem but the threaded rod end is completely covered in rust, but on my front adj trackbar the zinc coating has still held up, don't know why this would be.
I'll have to get some video of me wiggling it tomorrow
Question is, will JKS replace this for me or do I need to buy a new one?
Ill shoot them an email as well but I just wanted to see if any of you had any idea.
Just so you know if you have a part with a jam nut it must be tight.
If the jam nut is loose for any length of time it will "wollow" out the threads and creating slop.
If you give JKS a call I am sure they will help you out in some way
For everybody if you have anyting with a Jam nut ie. Control arms, Trackbars ect the Jam nut must be tight or the threads will fail over time.
David
David
