JKUR E disconnects question
Old Dec 24, 2013 | 06:26 PM
kellyII's Avatar
Default JKUR E disconnects question
I recently purchased a 08 JKUR with E- Disconnects. I'm not crazy about them to say the least. I have to get out of the vehicle and shake it side to side to get it to disconnect. I'm considering not using it. Maybe going to a manual quick disconnect. Maybe even a rock jock. Looking for input or input/advice.
Second. On my front axle lock the wire has been pued loose at the connector clip. Can I just wore them together Instead of ordering or trying to find the matching plastic clip??
Old Dec 24, 2013 | 06:33 PM
Jeek.OlllllllO's Avatar
Maybe the electrical part of it has gone bad why not instal the off road evolution no limit knob? I just bought a Rubi sway bar and what I plan on doing
Old Dec 24, 2013 | 06:42 PM
kellyII's Avatar
When I push the button you can hear it trying to engage. But I have to rock the jeep to get the light to quit flashing and to fully engage. Plus my sway bar is at a bad angle. It's not level, it's actuly upward. Maybe my
RK discos are too long
Old Dec 24, 2013 | 06:45 PM
Pictures might help of the sway bar it's self lol
Yeah might be the little motor that is going bad or you might just have a bunch of junk inside
Old Dec 24, 2013 | 06:49 PM
kellyII's Avatar
Will get a few tomorrow
Old Dec 24, 2013 | 06:52 PM
Yeah might have to do with longer links, are you trying to engage it on uneven ground or on the street?
Old Dec 24, 2013 | 06:54 PM
The long links shouldn't matter now that I think about it, but might have junk inside of it, or the unleveled ground.
Old Dec 25, 2013 | 03:27 AM
kellyII's Avatar
I tried engaging it on level ground
Old Dec 25, 2013 | 07:39 AM
jeeperjkjeeper's Avatar
I just recently had to pull my case apart due to the bar not re-engaging. The motor/plunger was working fine but the coupler and shaft were completely rusted and corroded. cleaned everything up and packed to marine grease around all mating parts and its back to working fine. I think long term I want to ditch the e-swaybar and simply go with quick disconnect links.
Old Dec 25, 2013 | 08:12 AM
ronjenx's Avatar
Having to rock the Jeep to get the bar to re-engage is normal. It will engage only when the master splines line up.
I don't rock mine. I just drive and when the splines line up, it will engage.
