just checking...tracbar angle ok?
Old Jul 26, 2011 | 07:33 AM
JEP THNG's Avatar
Default just checking...tracbar angle ok?
I know that these are supposed to be parallel, right? Does this look off? Thanks in advance.
Old Jul 26, 2011 | 09:04 AM
CM5280's Avatar
Hard to tell from the pics, but the drag link and track bar should be as close to parallel as possible.
Old Jul 26, 2011 | 09:25 AM
aermotor's Avatar
Need a pic that's more zoomed out so we can see most of the front end.
nthinuf's Avatar
You need a single pic showing the entire front end.
Try this one:
http://rides.webshots.com/video/3016...02496289IjoMUo
Old Jul 26, 2011 | 09:31 AM
Andrew@EVOMFG's Avatar
Sponsoring Manufacturer
EVO MFG Representative
Just to clarify for you... They are best when parallel or close to it. This will also change at different ride heights (lift heights).
The bars inbetween could technically do cork screws (I dont recommend ) but all the matters is the imaginary straight line between the center pivots of the trackbar joints and the draglink link joints.
If you really want to check it, tightly tape some string to the center of each joint and then stand back and look at them straight on.
Old Jul 26, 2011 | 01:28 PM
JEP THNG's Avatar
Try this one:
very helpful, thanks!
Old Jul 26, 2011 | 01:29 PM
JEP THNG's Avatar
thanks , I will try this.
