Just ordered my JKS Dicsos!
Thanks for the tip on buying them from Northridge! Can't beat the price and free shipping.
Should be here in about 5 days...just in time for my next Jeep trip. Any tips on install? I heard it's pretty straight forward and easy but anything I should take note of?
Eternal ***erator
righty tighty, lefty loosey.
get some big zip ties to secure the swaybar after disconnect.
The pin without the tapered end goes on the passenger side axle mount by the axle trackbar mount.
stop at a tractor supply store and get a few extra lynch pins for when you loose the ones they came with.
...that's about it.
...that's about it.
Take the stock links off of both sides first (ask me how I know this)
then put the passenger side on before you put the driver's side on.
also find something to fit in the pin hole that is long enough to give you leverage when you torque it.
Eternal ***erator
The disco didnt pop off, I was just missing the pin. a little bag of two pins was like $3. so i bought two. the extras are in the glove box.
I like putting things together like you mentioned on the carabiner, and that is a great idea.....
...but in my case, it just makes it more convenient for me to lose them all at the same time.
Lay the pins out...they are not all the same length.
The passenger side bottom one is flat tipped, but the other 3 are different from each other by a little bit, and its hard to get clearance for the bushing to slide on if you have a longer pin where the shorter one should go, etc.
Turning the steering as needed makes room to work too, as at least on my stock height JK, the steering was in the way of a decent reach in, etc.
Those socket/wrenches, the kind that are open ended and have a ratcheting section in the middle.....very handy.
I've used them now a few times, and the JK ones are just as easy as my TJ ones were...on/off in a breeze.
You can do 1 side at a time but make sure you are on level ground. Very level. You'll see very slight differences if it is not 100% level.
Don't forget to grease often while breaking them in.
