K&N Air Filter
Old Nov 3, 2008 | 03:56 PM
Default K&N Air Filter
Just purchased a K&N Cold Air In-Take Filter for my 08 Sahara.
Has anyone installed this item before? It seems straightforward, but after reviewing the installation instructions I noted an engine screw that needs to be loosened.
Does anyone know of any tips to follow for an easier installation process?
I am a bit of a novice and just need a few tips.
Old Nov 3, 2008 | 05:40 PM
metalcd's Avatar
highly recommend following the instructions, its generally the best way to do it. especially from a well experienced company.
Old Nov 3, 2008 | 06:24 PM
Denny2565's Avatar
I installed an S&B intake on my jeep and didn't have to loosen any bolts so you got me wondering. I went to the K&N site and looked at the instructions. It looks like the engine bolt you're talking about is used to hold a bracket that supports the intake pipe. So go ahead and remove it, but you will use it again when you attach the bracket.
By the way, the sensor is a pain to remove from the factory pipe. Here's some instructions that will make it much easier:
https://www.jk-forum.com/forums/jk-write-ups-39/air-temp-intake-sensor-removal-less-than-60-seconds-55433/
Old Nov 4, 2008 | 03:34 PM
Thank you and appreciate the feed. My concern was on how difficult would the bolt be to access and remove, but I really should be more concerned with the sensor.
The sensor can probably bring me more headaches. Thank you for the link!!!
Old Nov 4, 2008 | 03:42 PM
JCKnauer22's Avatar
x2 on the sensor. that thing can drive you nuts. ur just so worried about breaking it. best of luck
Old Nov 7, 2008 | 03:02 AM
Jk863's Avatar
I recently installed my K&N and the directions are straight forward. Follow the directions it will be easier than you think. Make sure you tighten clamps. Go easy removing and installing the sensor from the stock unit it's fragile. I think you will like it when your done. Good luck
Old Nov 7, 2008 | 04:47 AM
2drREDROCK's Avatar
Very easy a couple bolts a jerk and its out
I also installed the K&N intake and I love it I wish Mopar would have made this stock
It sounds awesome and gives a little kick,congrats on the Intake
I just followed the instructions and they were right on the money,very good company K&N rocks
