Kilby Engine Skid
how are oil changes with the Kilby skid? Is the drain plug easy to get too, and does it make a mess, or do things stay pretty clean with that back splash they have welded on there?
Well after much debate, I have ordered the RockHard skid. Hopefully I won't have the exhaust clearance issue. I have a Magnaflow catback, and it looks like it sit's pretty high, so we'll see. My fingers are crossed. I will definitely feel better off-road once I have the skid in place.
RockHard Skid
I have encountered the exhaust cross over touching the skid creating a vibration. I won't completely fault Rockhard for this and primarily attribute it to variations in JK production. Fixes under consideration are to simply use washers between the skid plate and trans support brace or loosen the bolts on the exhaust manifolds and where the two pipes join into one and see if it can be moved up a bit then retighten loosened bolts. Another less favorable option is to have a muffler shop modify the exhaust cross over.
I also had an issue with the transfer case skid. I'll fault Rockhard for this one. The problem is its not shaped or contoured correctly to bolt on to the attachment points. As a result it needs to be forced a bit to bolt on to the frame rail contact point. I contacted Rockhard and they confirmed this issue, but they did not think it was a big problem. Rockhard said just tighten the frame rail bolt last. I don't agree. My perspective is when I pay good money for parts I expect them to fit/bolt on properly. They should not have to be forced into place. Because of this I am not sure I will buy their gas tank skid even though I think their the only ones who make one.
Hope that helps.
I have the Rockhard engine/trans skid, transfer case skid, and evap skid for my 2007 JK 2dr Rubicon. In general I think the build quality is good.
Hope that helps.
Hope that helps.
