knocking noise when flexing...
Old Aug 18, 2009 | 10:54 AM
rome07JK's Avatar
Default knocking noise when flexing...
i went out and did some serious wheeling yesterday on some very difficult trails and i kept noticing this knocking noise coming from under the jeep...i have a 3.5" lift and i was thinking maybe it was the driveshaft hitting somewhere? i didnt really notice it when i was flexing with the wheel straight it was mostly when i was flexing with the wheels turned to either side...
Old Aug 18, 2009 | 10:57 AM
racer83l's Avatar
I know, one of my bumpstop extensions arent quite mounted straight, and when the spring compresses, it acually hits the bumpstop making a knocking noise.. maybe you have the same issue??
Old Aug 18, 2009 | 12:10 PM
Littlejon's Avatar
If it is only when you are turning and flexed up I would guess it is a tire hitting someplace, and you are hearing the lugs rubbing.
Old Aug 19, 2009 | 07:27 AM
themaniam1's Avatar
Check and see if your track bar is hitting your diff cover. Very common when doing some major flexing. It will be more like a single clank then a rubbing sound. Look for paint scrapped.
