LA front/SA rear
Old Oct 12, 2014 | 09:04 AM
OCOutdoors's Avatar
Default LA front/SA rear
This may be a dumb question but I've been researching long arm vs short arm and have to ask. Seems the biggest downfall to LA is they are more prone to getting hung up, what if you used high clearance LA in the front and left the rear SA?
Old Oct 12, 2014 | 01:43 PM
Collyn's Avatar
Huh? I guess it could be done, but why? It just seems wrong. It sounds as bad as running staggered wheels and tires on a 4wd. Haha.
Old Oct 12, 2014 | 01:51 PM
kjeeper10's Avatar
Vet Army
He's asking about running LA in the front only. Why not.
I was looking into the Clayton front setup which is high clearance/bolt on on. Then do the rear at a later time.
2007 Rubicon /2 door/6 speed
Old Oct 12, 2014 | 02:05 PM
OCOutdoors's Avatar
Thank You kjeeper10, I didn't think it was too off of a question. I was thinking you would get the best of both worlds, stability with LA front and clearance with SA rear unless arms need to be same length front/rear.
Old Oct 12, 2014 | 04:28 PM
kjeeper10's Avatar
Vet Army
Not front to rear. Uppers should be a percentage shorter then the lowers.
Old Oct 12, 2014 | 05:27 PM
OC-JK's Avatar
Yes you can ran long arm in the front, short arm in the back. I have a friend who has a teraflex long arm in the front only and loves how drives/wheels and has no plans to add the rear long arms to it.
Old Oct 12, 2014 | 06:43 PM
OCOutdoors's Avatar
That's some good info.. Would like to hear from others as well.
