Largest tires on 18's ??
Old Apr 29, 2007 | 05:31 AM
bodybrdng's Avatar
Default Largest tires on 18's ??
First time jeep owner. I just bought a 2dr Sahara with the factory 18's. Does anyone know the largest tires I can put on there with out modifying anything? Sorry if this thread has already been posted. I have been looking all over the internet for days now. Thank you.
Old Apr 29, 2007 | 08:27 AM
JKMAN's Avatar
33x12.5x18 but you would need wheel spacers.
Old Apr 29, 2007 | 10:20 AM
bodybrdng's Avatar
Post
What size spacers?
Old Apr 29, 2007 | 11:34 AM
arincmax's Avatar
Originally Posted by bodybrdng
What size spacers?
You can install 33X12.50R18 without a wheel spacer , but you will rub at full lock,
assuming your using stock wheels . I'm running 1 inch Terraflex wheel spacer
with no rub .Many people are also using 1.5 spacer with no issue.
When off roading u will be very limited without a lift.
Old Apr 29, 2007 | 11:35 AM
TwinsJeep's Avatar
You'll find that you can go to a 285/65 18 but will rub at full lock (side-to-side turn)... I should say, with the BFG All Terrain T/A KO you'll rub; a less aggressive/blocky tread face in that same size might not rub.
When I pick up my 4-dr Sahara this coming week ( at last!), I'll be driving directly to the tire shop to swap out the stock tires for a new set of 5 Bridgestone Dueler A/T Revos in 265/70 18... should be no rubbing whatsoever... and the speedo won't need recalibrating (it will be slow by 1.7%, meaning that when the speedo shows 60 mph I will actually be travelling 61mph).
Old Apr 29, 2007 | 11:44 AM
possumface's Avatar
isn't the 18" tires 32" by going to 33" tires are u really only getting 1" difference
Old Apr 29, 2007 | 12:34 PM
TwinsJeep's Avatar
That's right... and in my case, from a 255/70 18 to a 265/70 18, I'm not even gaining an inch in height or width. But my purchase isn't motivated by a desire to go "big"... If that's what I was looking for I'd lift and buy new wheels and much larger tires. But that's not my goal. Here's my logic...
First, from my research the REVO is a highly rated all terrain that satisfies on road and off (mild off road, no mud, no rock crawling). Next, it's beefier and more aggressive than stock, making it (IMO) an upgrade for the stock rims without requiring any mods whatsoever. By purchasing this tire now instead of waiting until my stock tires wear out, I gain multiple benefits: 1. about $500 of trade-in value on my pulloffs toward the new set of 5 REVOs; 2. 50,000 mile warranty; 3. 5-year road hazzard; 4. lifetime balance/rotation.
Really, my goal was just to put on better, bigger and more aggressive tires that wouldn't require mods and would improve both on road and off road handling.
Old Apr 29, 2007 | 04:27 PM
moparmadness's Avatar
Thumbs up
WHERE ARE YOU GETTING THESE TIRES WITH A 50,000 MILE WARRANTY? HOW MUCH BIGGER ARE THE TIRES THAN STOCK? SOUNDS LIKE A GOOD DEAL WITH THAT WARRANTY!!
LET US KNOW!
Old Apr 29, 2007 | 05:48 PM
TwinsJeep's Avatar
Bridgestone Dueler A/T Revo. I'm dealing with a chain called KalTire.
As regards warranty, check out the Bridgestone website... I'm assuming that the same warranty is offered in the States.
And as for size vs. stock: (stock) 255/70 18 = 32.05 x 10.03; 265/70 18 = 32.60 x 10.43. So, 0.55" taller and 0.4" wider than stock.
