Leak by C?
Old Sep 4, 2021 | 07:08 PM
jkman93's Avatar
Default Leak by C?
I noticed this leak here on the driver’s side. The passenger side is dry. What do you think the issue is?
Old Sep 4, 2021 | 07:26 PM
ronjenx's Avatar
Could be leaking axle seal, at the inner end of the tube, by the differential.
Could be residue from recent work, if shaft was removed.
Clean it with brake-cleaner. Check fluid level. Keep an eye on it; see if it continues to leak.
I had the same condition about 200,000 miles ago. Cleaned it up. It has been dry since.
Old Sep 5, 2021 | 12:35 PM
resharp001's Avatar
Loved
Community Favorite
+1
You're likely looking at a seal replacement. Good news is ~$20 per seal, bad news is ~3hrs or so for most folks to replace them themself assuming some decent tools, or $250+ in labor typically to have a shop do it. (you do both even if 1 is leaking). Do as Ronjenx said first, clean and monitor. The jeep won't blow up anytime soon, but typically these things don't get better with time.
