Leaning to the right
Desert Warrior (12-21-2022)
Here's another one I ran into did you measure out your coils before installing them? Like put them next to each other and see if they were the same or if one was a bit taller?
I weighed my stock JK with a scale under each tire. It was very well balanced from side to side with half a tank of fuel, no occupants, no tools, etc. inside.
The front/rear distribution was 52% front, 48% rear. Sounds like a well balanced vehicle from the factory.
Something else is going on with those that lean to one side or the other.
Front Driver - 1370
Front Passenger - 1378
Rear Driver - 1128
Rear Passenger - 1193
Passenger - 50.7%
Rear - 45.8%
I've had the same coils (RK 2.5") for several years... no lean either direction.
I think it balances out very well. Something else is causing some JKs to lean to the right.
Mine was also leaning to the right. I figured it was my Rock krawler 2.5" springs starting to sag so I changed them out to metalcloak 3.5" but it still leaned. I put a 3/4" spacer on the passenger side front and it leveled it out perfect.
Have a jku on 40s with a 3" lift and a few months ago I noticed that over time the coils on the right had been sagging so I thought it was just shitty rough country coils. I replaced them with teraflex coils and now they are doing the same thing. Any idea what could be causing it? Nothing heavy is on that side. Maybe a bent rear sway bar? Can anyone help?
Same lean and it's really pissing me off, very noticeable even from the front. Had the lift on for 2.5 years with no issues until a few months ago. Even spun the coil around to try and fix the bow but no luck. Still a full gangsta lean even with an empty gas tank.....ugh
2010 JKUR | 2.5 RK Max Travel | 35 Toyo MTs | Crawler Conceptz Skinny front/Smitty rear | 5.13 Yukon | Superchips
To determine the cause of the lean take any load you carry out of the rig, adjust the fuel load to 1/2 full if possible and disconnect the front & rear sway bar links. If there's no change in the lean un-bolt the rear track bar from the axle. If still no change, swap the rear springs side to side. If there's still no change add a spacer above the passenger rear spring equal to the amount of lean. Bolt all back up, done.
In general the preliminary steps will identify the cause, twisted sway bar, incorrect link lengths, incorrect track bar length, sagging rear spring, etc.
I've noticed mine leans to the right too, and the springs are brand new, i had the lean with brand new Rubicon Express springs, and those fackers have crazy pressure rates, had them not even for 2 months and i had them switched to OME's light duty, lean is still there, i have had the springs for only 2 weeks or so, and i just threw a high lift jack with the Rudge ridge tube bars inside yesterday, had the base of the jack facing the driver side hoping a little weigh will seat that side a little better, lol, didn't do shit i think, but i gave it a try, and now i have a hi lift jack
Check your rear springs to see is they're arched, i bet the rear passenger has a more pronounced bow. you can always add something like a 10mm spacer on the side that has the biggest lean, i'd assume in the JK that would the rear passenger side as that is where the gas tank is.
do like the rest of us have done, drink alot of beer, eat alot of pizza, stay away from the gym and before you know it with you in the driver side there is no more lean.
