Which LED Tail Lights?
Old Mar 22, 2015 | 10:49 AM
  #21
rodi's Avatar
Originally Posted by ChairRepairHeatnAir
Yes. I think the turn signal wire is the only one the canbus monitors because the stock bulb is a dual filament. I wired the resistor from the turn signal hot to the ground wire.
Thank you. I just need a little more clarification. Where exactly did you do that? At the lamp end or somewhere up front?
Old Mar 22, 2015 | 12:12 PM
  #22
MotoJeeper's Avatar
Veteran: Marine Corp
At the lamp end. Metalcloak has you cut off and re-use the pigtail from the original taillights and wire the OE plug to their taillight. I put the resistor on the taillight side to make it easier to wire it. They just hang down in the hole. The resistor creates heat, so you want to make sure that it doesn't touch any plastic.
