Level advice help!
Old Mar 18, 2014 | 04:29 PM
USMC03's Avatar
Default Level advice help!
I am currently running 285 70 17 duratracs with mt classis 2 17x9. I cant stand thr factory rake so do i go with the teraflex 2 in the front 1 in the rear or should i just get a coil spacer for the front only. I dont do any offroading.
Old Mar 19, 2014 | 01:29 AM
Kojack's Avatar
I would go with the teraflex leveling kit. That's what I run. I love it. I also installed Monroe reflex monotube shocks and the ride with this combo is fantastic. Im 100 percent happy.
Old Mar 19, 2014 | 02:18 AM
Billbikes's Avatar
If you're happy with the height, all you really need is the spacer up front, but I'd personally do both. After a week you won't even notice it, and you won't have to worry about running if you load down your Jeep.
Old Mar 19, 2014 | 03:06 AM
Battlefrog21's Avatar
I would go with a front spacer first and see if it levels out before doing the rear. Might wind back to where you started...
Old Mar 19, 2014 | 07:53 AM
Kojack's Avatar
You will be fine with the teraflex leveling kit, its made to level out the Jeep with all spacers in. just gives you a little better stance with the rear spacers and 2 inch up front.
