leveling kit
Old Apr 18, 2013 | 01:52 AM
r/t's Avatar
r/t
Default leveling kit
First off let me say I have did a lot of reading and can't determand witch is the correct answere.
We have a 2012 JK 2 door and have the following hanging off the front.
Smity Built XRC with full width extenchions and a warn VR10,000 winch.
it apears to have droped the front 3/4"+ what spacer or Springs will bring it back to level & keep it there?
R/T
Old Apr 18, 2013 | 02:27 AM
blue project's Avatar
I went with the teraflex coil spring leveling kit and 1/2 spacers because of the weight of my bumpers. Just adding a 3/4 front spacer should put you back to stock. Leveling kit and spacers will give you the best of both worlds and be able to run up to a 34" tire.
Old Apr 18, 2013 | 02:59 AM
Gman*2007's Avatar
If you wanted an easy way out, install a higher spring rate number up front for the time being to get your stance back. Welcome to the forum.
Old Apr 18, 2013 | 03:01 AM
catahoula's Avatar
X2 to both replies. Daystar or Teraflex spacer or higher rate of spring say off a for door to keep it inexpensive.
Welcome to the forum!
