life question...
I am looking to put a 2.5 inch lift on my 2012 JK. I have read that I will need to replace my front drive shaft if I do this. But If I don't ever plan on disconnected my sway bar links, would it be an issue if I don't replace my drive shaft? thanks. I am mainly just going for looks and a little more clearance. i don't do much offroading and the little that I do is just for hunting or the dunes at silver lake michigan.
I've heard that when fully extended in will rub on the exhaust. but if i'm never disconnected wouldn't that mean I probably wouldn't ever rub? I don't want break it, so I am hoping for some helpful and tested thoughts. Thanks in advance.
Auto or manual? And how centered are the axels. The front shaft may hit the tranny skid even if your still connected. So, it's best to just keep an eye on the boot and think about a future drive shaft. If your rig is a 2 door, think about both. May I suggest diff covers too. Once lifted, you may drive a bit more aggressive, and the stock covers are stamped steel that peel away from the pumpkin.
A 2.5 inch lift wont be an issue. Not enough droop to rub. If you get more than 3.5 or so, you will see that the droop on the front drive shaft will cause the boot to rub. Use the sway bar disconnects all you want, no worries.
