lift
Im purchasing a rusty's 3.25 inch basic lift kit and I want it to sit a little higher so i was thinking about adding some coil spacers. Do I need anything else or can i just through them on with no problem?
even if you add 1" coil spacers, you will be effectively sitting at about 4" or taller and that's a lot of lift. at that height, you really should install a track bar relocation bracket and dropped pitman arm or draglink flip and, if you don't have them already, adjustable front lower control arms to add a bit more caster, longer brake lines and drive shafts. unless you have the budget to go all the way, i might recommend that you just stick with the 3.25"
